跳转到主内容
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Why does my Mac Pro get stuck when I restart it?
If I've updated software etc, I click on the apple and choose restart, it seems to be heading that way and goes black etc, then I just hear the clicking noise from the tower expected with a restart, but continually, about every 5 seconds, and the screen stays black. I eventually give up and hold down the power button until it turns off then I switch it on again and it runs like normal.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
Clicking noises can be an indication of a failing hard drive. It's the reader head going back and forth. It can also be a very fragmented drive and the system data may be all over the drive and it's having a hard time finding it. How full is the drive? Does it boot from the original system installation DVD? Have you backed up your data to another internal or external drive, if not do so ASAP. Run Disk Utilities on the drive from the installation DVD.
这个答案有帮助吗?
得分 4
16条评论:
It's just recently been wiped and reinstalled OS 10.7.5 so there's not much on there atm. I thought perhaps installation of some software may have done it. K9 which helps keep internet safe for my kids. I uninstalled it but issue remains. Might have to just wipe it again and try again. Thank you!
完成的
Hard Drives will develop bad blocks (sometimes they come with them), To map these out use the "write zeros" option when formatting the hard drive. It takes a while as it writes to each block on the hard drive then updates the directory as to where the bad blocks are and not to write to them.
完成的
Actually the clicking noise the poster refers to (as I have the exact same problem) is the optical drive resetting... see my post below.
完成的
Gabriel I might agree if this was a laptop. I've used Mac Pros for years and it is my everyday machine and i do not get this.
完成的
Then hear closer. There is a "relaxing" sound when an optical drive gets a reset, along with an impulse to the fans... My current machine has it, my previous machine had it and every single one I worked with during my 7 years at Apple had it... Maybe we're just not understanding the same thing under "click".
Anyway, that is not the point. The point is that Sue's (and my) machine is stuck in trying to get to the chime when restarting...
完成的
显示更多的11条评论
添加一条评论
Actually the clicking noise the poster refers to (as I have the exact same problem) is the optical drive resetting... and since that power cycle goes in a loop, you hear that again and again and again along with the fans blowing and calming down, then blowing again, then calming down again... typical restart stuck at some point then starts over....
这个答案有帮助吗?
得分 1
3条评论:
I have this problem for maybe more than a year and have not been able to find a fix. At one point someone suggested I replace the battery on the motherboard... did that... the first restart went ok, then again... cycle...
If I reset the SMC (unplug for 15 seconds, replug, wait 5), the first restart works... but after that again.. cycle...
完成的
After you find a fix for this problem, then tell us about it,
完成的
Sue? Ever getting back at this thread??
完成的
添加一条评论
I got rid of the problem. My Mac Pro is restarting correctly 100% of the time now.
Please, Sue, if you're reading. Confirm using System Profiler, that you have ROM version MP11.005D.B00
If so, I assume you have a CTO (customized-to-order) Mac Pro 1,1.
Let me know.
这个答案有帮助吗?
得分 0
10条评论:
Gabriel,
I have this same problem, quite annoying. How did you fix this?
完成的
Is your ROM version number the same as the one I quoted? MP11.005D.B00 ?
完成的
yes, my ROM is the same as your
完成的
You need to update the firmware in any direction as this version has this bug. You need to either upgrade (to the Mac Pro 2,1 firmware as this is the last one for the 1,1), or go back to the previous release for the Mac Pro 1,1.
If you opt for the 1,1 to 2,1 route, here's an installer (the official Apple does not recognize the B00 ROM as upgrade-able). This is the upgrade tool I used:
http://tillmanmusic.net/Apple_improvemen...
By the way, after the upgrade, you can make an 8-core machine if you want as it will support all the CPUs of the 2,1 configs :)
If you have a non-standard GPU in the machine, go back to some stock Apple GPU to do the firmware update as I had issues upgrading while my Geforce GTX 680 was in there.
You'll find instructions for updating the firmware all over the net. Good luck!
Bye,
Gabriel
完成的
Hey Gabriel - don't know if you get back here but . . . I'm going through the same problem with my MP 1,1 booting up just fine but not able to restart, including hearing the clicking of the optical drive. Just curious if updating the firmware is going to work as the machine needs to restart to complete the process? (My current Boot Rom: MP11.005D.B00)
完成的
显示更多的5条评论
添加一条评论
Hi all,
thorwing my hat in here with a "me too" on the clicky-no-rebooty.
I tried updating to the new firmware as per Gabriel's posts and it wasn't sucessful. System profiler says I'm at version MP11.005C.B08, SMC 1.7f10.
I'm getting the same symptoms as Peter, diag LEDs 2&3 blinking and then a never-ending clicking coming from the optical drive or the power supply while the poor thing tries to reboot.
这个答案有帮助吗?
得分 0
5条评论:
Hey MikeBougie - surprisingly my issue turned out to be having installed bad RAM, or at least that's what was triggering the issue. If you want to know more specifics with my "clicky-no-rebooty" to see if it's what you're experiencing, the link to my post is here: Mac Pro 1,1 A1186 will boot and sleep, but not restart..
Shortly after I put the old RAM back in and was restarting fine, I got a power management issue which I haven't dealt with yet. I only mention it as it may all be related but at this point, I'm not sure.
Good Luck
完成的
You don’t have the buggy Boot ROM so I’m betting you’re in Peter’s shoes. Check the RAM... Let us know how it goes!
Good luck!
完成的
You could also try pressing the System reset switch although for me it didn't work, rather starting the "clicky-no-booty" issue. But is is listed as one of the diagnostic steps to try. In my situation, getting stuck by way of the System reset switch resulted in a brief flash from Diagnostic LED 7 immediately after the flash from LEDs 2 & 3 which didn't happen when simply restarting. I also tried removing the optical drives but that only made the situation silent, as in no "clicky", but still ended up with "no-rebooty". Just a couple other things to try.
完成的
I'm betting on a RAM or RAM riser board issue (or CPU seating but it is unlikely). I would try pulling out the RAM risers and the RAMs, clean the contacts with isopropyl alcohol (nothing else!), reassemble and see if that helps. If not, remove all the RAMs and start up witha few _known_ good RAM only and check if the problem persists.
完成的
Hi all! I'm thinking that it's bad RAM. A few years ago I bought some "Certified" MacPro RAM off eBay and IIRC that's the when the issue started. I'm going to pick up some Apple genuine RAM from MacRamDirect.com and see if that fixes the issue.
完成的
添加一条评论
添加你的答案
Sue 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 47
总计 2,560
