跳转到主内容
Repair guides and support for phones manufactured by BLU Products. BLU stands for 'Bold Like Us.'
1766 个问题 查看全部
问题已关闭
mobile network not available
worked this moring when calling to doctor but not working now at 3pm still can't get work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 14
14条评论
My phone would not turn on
完成的
My network not working how to fix
完成的
How do I get pass my google count to open it? My blue sell phone?
完成的
Mere moile ka network cale ghe Hi
完成的
My data is not responding, I cannot browse, look Facebook. Pls to me how to set it up on blu phone vivo 5 mini
完成的
显示更多的9条评论
添加一条评论
8个答案
最有帮助的答案
Some Simple Solutions:
Solution#1
  • Switch off your smartphone.
  • Remove bettery and also your Sim Card and wait for some time.
  • Reinsert battery and sim card and turn your phone on.
Solution#2
Set your mobile network to automatic .
Solution#3
Update your phone software.
These solution will probably fix error while searching for networks.
Hope it helps.
这个答案有帮助吗?
得分 3
添加一条评论
restart phone,
if not get network check airplane mode is ON, if it ON then turn off it
still not have network, check imei by dialing *#06#
if it error rewrite imei code
if it not error
need to check network connection part
这个答案有帮助吗?
得分 1
添加一条评论
Which sim do you have. go to setting and mobile network and try manual search for mobile network. and look for your network and register it. Or go to setting sim management and then disable sim and then again reactive it. or lastly remove sim and insert again.
这个答案有帮助吗?
得分 0
添加一条评论
click here to know how you can fix this error
这个答案有帮助吗?
得分 0
添加一条评论
SIM cards can go bad, if all else fails, go back to your carrier store.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem but I finally figured it out!! I went to settings/ cellular network/billing cycle. If “set data warning” is on, turn it off. If “set data limit” is on, set it unreasonably high just in case (15.0) and turn it off. The reason my Cellular data wasn't working is because it was set to turn off when the limit was reached! Hope this helps you too!
这个答案有帮助吗?
得分 0
1条评论:
My phone doesn't work any application
Not working
Facebook
Whatup
Play store
Time and date problem issued
完成的
添加一条评论
Check you're APN. If you have certain cellcarrier, then your APN may need configured. I have att and had this problem to and shutting down phone didn't help. It kept doing it. Finally someone told me about APN and haven't had the issue since.
这个答案有帮助吗?
得分 0
添加一条评论
Contact your carrier often they can help
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 47,935
