mobile network not available
worked this moring when calling to doctor but not working now at 3pm still can't get work.
Some Simple Solutions:
Solution#1
Solution#2
Set your mobile network to automatic .
Solution#3
Update your phone software.
These solution will probably fix error while searching for networks.
Hope it helps.
这个答案有帮助吗?
restart phone,
if not get network check airplane mode is ON, if it ON then turn off it
still not have network, check imei by dialing *#06#
if it error rewrite imei code
if it not error
need to check network connection part
这个答案有帮助吗?
Which sim do you have. go to setting and mobile network and try manual search for mobile network. and look for your network and register it. Or go to setting sim management and then disable sim and then again reactive it. or lastly remove sim and insert again.
这个答案有帮助吗?
I had the same problem but I finally figured it out!! I went to settings/ cellular network/billing cycle. If “set data warning” is on, turn it off. If “set data limit” is on, set it unreasonably high just in case (15.0) and turn it off. The reason my Cellular data wasn't working is because it was set to turn off when the limit was reached! Hope this helps you too!
这个答案有帮助吗?
My phone doesn't work any application
Not working
Whatup
Play store
Time and date problem issued
Check you're APN. If you have certain cellcarrier, then your APN may need configured. I have att and had this problem to and shutting down phone didn't help. It kept doing it. Finally someone told me about APN and haven't had the issue since.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 47,932
14条评论
My phone would not turn on
由 wilmab 完成的
My network not working how to fix
由 Letisha Palmer 完成的
How do I get pass my google count to open it? My blue sell phone?
由 brodersonjulie 完成的
Mere moile ka network cale ghe Hi
由 kamran aman 完成的
My data is not responding, I cannot browse, look Facebook. Pls to me how to set it up on blu phone vivo 5 mini
由 Ginette Mande 完成的
显示更多的9条评论
