跳转到主内容
加入维修社区 - 创建账户
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
MacBook battery doesn't work after RAM upgrade, no chime
I just followed the guide for replace my MacBook Pro RAM from 4GB to 8GB (one chip), when I reconnected the battary it won't work and my Mac won't startup! The battary light indicator isn't showing any light, when I connect to Magsafe to power source it lights in green but still not charging nor starting up. Can someone help me where did it go wrong and how to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
The RAM upgrade probably had nothing to do with it. Most likely is that you unplugged the battery for the installation and failed to plug it back in. You might have bent a pin.
这个答案有帮助吗?
得分 2
9条评论:
@mayer How can I ensure that I plug it back in correctly? All pins look perfectly fine to me.
It's very straight forward task!
Also I'm unable to boot the device when connected to external power source. I'm using 60W MagSafe adaptor.
完成的
Switch the old RAM back. Have you had any prior issues, any video issues at all?
完成的
@mayer I already tried that still the same. No significant at all.
完成的
Did you turn the system off fully before taking the RAM out (disconnect the battery)? If the system was still powered when you pulled the RAM you could have damaged the logic board.
Also, did you practice good ESD protection? It's winter with dry air static is a killer as well.
完成的
@danj Yes it was fully shut down, then I disconnected the battery.
Um I'm not sure what I was supposed to do to ensure ESD protection?
BTW I removed the old RAM and put it back in couple of times, before I inserted the new RAM chips. The only difference is that this time I disconnected the battery. When I was experiencing with the old RAM (removed one and left one, then put them both back) I didn't face any issues and my system recognized these changes.
完成的
显示更多的4条评论
添加一条评论
You be sure the firmware update is correctly.
First you need do a PRAM with the machine connected to power.
That is done with the folowing secuence : Command (cmd) + Option (alt) + P + R on a keyboard inmediatly after power on.
Hear 3 beep, following hold off the keys, is the computer didnt startup , may be the damage is more deep and sugest go to a service center.
PD try without battery.
这个答案有帮助吗?
得分 0
1条评论:
@irepair I can't do a PRAM, It won't power on with or without battery.
完成的
添加一条评论
添加你的答案
r1m111 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 421
