跳转到主内容
修复任天堂游戏机和配件的信息。
5271 个问题 查看全部
Signs of life in N64
I just got myself a N64 for my birthday and nothing I do makes my TV's (newer LG 62in and new Roku 32 in tv... I have another insignia 40 in I haven't tried it on but after the first 2 I figured it was the system or the fact that these are newer tvs) acknowledge it's connected.... Now the red light is on, but to be honest I haven't had an n64 in over a decade... what should I be looking for to make sure I didn't get a dead system? ( have 3 days to return before I'm stuck with it, so I need to know 100% it's my tvs not the system!) The light comes on but it makes NO sound, no fan noise, no turning on noise, nothing, is that normal?
Thanks in advance for any replies/help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
Do the TV's you are using have any RC connectors Yellow for Video, Red and White Audio. If they do then you should be able to connect and get the unit to work. If it doesn't then it is probably broken. Do you have a DVD Player that has audio and video inputs. If so then you could test it on that as well. Again if it doesn't turn on and have video then it is broken. You should not have to mess with anything it should work as is. The TV would need to be source of AV1 or AV2 depending on the RC Connector's label that you use. A DVD Player should automatically detect the input. Of Course sometimes their remotes might have a source button. But if the Console is working it should be easy to tell and you shouldn't have to be searching for the video so hard.
完成的
添加一条评论
1个答案
GET A TUBE TV FOR GODS SAKE DOOD!
Unless you wanna resolver the motherboard, i suggest getting an old ass tv.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Leeza 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 197
