iMac 24 keeps shutting down
Hi, have had this problem for a while now, the imac just shuts off like the power was cut. Just wanted to know how to find the problem as I would prefer to fix it myself if possible. Have looked in the console but no power issues.
Thanks for your help
Gerry
Update (02/20/2016)
All the lights on etc. When I unlatch lcd light goes off. Can't understand why it just shuts down. Don't wanna buy a psu if it something else plus don't wanna pay for unnecessary repairs if I can do it myself
Update (02/24/2016)
Still going off. All the led lights are on when supposed to be. Can stay on for a long time then go into sleep mode but when I start an app it goes off. Help with this would be greatly appreciated. Is there somewhere in the log where I would find out the problem?
Update (03/03/2016)
It's a last shutdown cause the code number. I haven't a clue what to try now. Took the logic board out yesterday. No dust on Gan or in the vents of the logic board
Update (03/04/2016)
Update (03/04/2016)
Me again. Just did the full extended hardware test. No problem. Reinstalling el capitan at the moment. If my HD is dead would it still shut down while running off external drive. How do I check if fan behind. Logic board is running since I have to take it out to see. I think I might just have to give up and put some money away to buy another Mac
7条评论
PS it doesn't shut down in safe mode
由 gerard murphy 完成的
Boot up from your original system installation DVD to see if this is possible software issue. Next boot from the DVD holding down the "D" key and run diagnostics.
由 mayer 完成的
Ok I'll give it a try if the cd drive doesn't spit it out
由 gerard murphy 完成的
I think you'll need to get someone local to help you here. Things are just not adding up. If you can go into Safe Mode with no problems that would imply you have a HD or OS level issue. But you also state a known good external bootable drive or OS CD/DVD won't work either.
由 Dan 完成的
Install the app I pointed you to in my first answer TG Pro
由 Dan 完成的
显示更多的2条评论
