跳转到主内容
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
Is it possible to upgrade its CPU for a Core2Duo ?
I've read on Hardmac that the CPU of this iMac could be upgraded from CoreDuo to a powerful Core2Duo. Have you ever done it ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Yes, you can upgrade the Core Duo Imac,
Here is a Guide
这个答案有帮助吗?
得分 4
添加一条评论
I finally replace my Core Duo on my iMac from 2006 by a Core 2 Duo 7400 !!! Il works great and the replacement was pretty much easy with patience. I also put a new power supply because the original, a rev.a, seems to cause unpredictable shutdown ... il looks like a component not design by Apple but by my dumb neighbour with his feet ;-)
Again, thx matthewfrey for your precious link.
Cheers from France !
这个答案有帮助吗?
得分 1
添加一条评论
Yes and no!
The CPU on these models are permanently mounted on the logic board.
However, most all of the parts between the Model A1174 (with a 2 GHz Core Duo processor) and the Model A1207 (with either 2.16 or 2.33 GHz Core 2 Duo processors) are the same. Therefore, you could upgrade to the Core 2 Duo by replacing the logic board.
I hope this helps!
这个答案有帮助吗?
得分 0
1条评论:
This is incorrect. The process is a zif socket: Core Duo CPU upgrade to Core 2 Duo CPU?
完成的
添加一条评论
Thanx Ben & thanx a lot Matthewfrey ... I'm going to refresh my iMac !
Happy Xmas & New Year !!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Francois Besson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 4,743
