跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1696 个问题 查看全部
Powersupply connector is stuck!
My PS4 is over 1 year and it's about time to break those seals and give it a Clean and new paste. BUT I can't get passed the PSU!
The connector in the mainboard is stuck! I've tried to pull as hard as i possibly can but nothing!
I'm sure it would come loose if I gave it a really hard quick pull but I'm also pretty sure the soldered connector also would come loose of the Circuit board. If i do that I might aswell just grab the whole PSU and just jump and see which part comes loose...
What the !&&* do I do??!!! I need to Clean it NOW Before the hitman beta uns out. Can't play it the fan runs in 100% all the time and I cannot even hear the gamesound from my speakers.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
There is a small area on the right side (the side with the connector) where you can get your finger (or some type of pry tool) and pry up on it. Obviously you don't want to break anything but you will need to pry hard to get it up.
I hope this helps.
这个答案有帮助吗?
得分 3
1条评论:
When you say 'right side', from which side are you looking at the connector? I have the back of the PS4 towards me and the connector is vertical, On the right of the connector it is completely flat with no detail whatsoever - the othe side has 3 scores on it. What do I need to pry?
完成的
添加一条评论
添加你的答案
charkel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 28
总计 8,198
