跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Error 53, torn touch ID cable
Hi.
I broke my screen and tried to repair it myself. Unfortanetly I managed to torn the touch id cable in two. I could use it for a while but after upgrading the phone I get this error 53. Is there someway to fix this and is it possible to fix the cable perhaps?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
It is possible, however this is neurosurgery level handcraft.
这个答案有帮助吗?
得分 2
添加一条评论
yes, send your phone to apple, cost you 119€ for a new home button with touch id.
这个答案有帮助吗?
得分 1
2条评论:
Are you sure it is that cheap? They wanted like 300 to fix the screen.
完成的
yeah sure other people here can confirm that normally.
maybe 300 for full screen but you only need home button.
完成的
添加一条评论
Hi Henric
You can try to replace the long cable and it may work after that.
If you have damaged the home button you need to replace it with apple, but the long flex cable is not a problem to replace and it may work. Try it and let me know please.
Hope this help
Thanks
这个答案有帮助吗?
得分 1
2条评论:
Hi.
I bought a new button and a cable, but changing them wont probably work. The problem is that both sides teared, the cable on the touch button and the long cable.
完成的
If both of them are broken then you need to contact Apple to get it sorted. Sorry
完成的
添加一条评论
添加你的答案
Henrik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 7
总计 210
