跳转到主内容
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
213 个问题 查看全部
water leaking in the back of the wash machine
When the water runs in the washing machine it leaks in the back what would that be
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
There are two hoses that run from the inlet valves (faucets) to the washing machine. Check to see where the leak is coming from, probably with at the valve or where they hook up to the washer. Could be just old washers.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Catherine Campbell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 392
