跳转到主内容
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
143 个问题 查看全部
How can I exactly locating the physical bad sector
how can i exactly locating the *physical* **bad sector** ?
_&_ what's best way to locate it ?
_&_ and kindly provide me the best program for detecting if the **hard-disk**
has *bad sectors* or not ?
i have tried with this program "Hard Disk Sentinel" but i think it's not work
waiting for your kindly answers
Regards
Jebrel
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
What model hard drive? What model computer? what errors do you get? Does your computer recognize your drive? What have you tried?
完成的
添加一条评论
1个答案
  1. Go to the search bar and type “Command Prompt”. Click on “Run as Administrator”.
  2. Type the command “chkdsk C: /f /r /x” and press Enter. (Or the Drive letter which is having the bad sectors)
  3. The utility will scan the hard drive for errors and attempt to fix them.
  4. Restart your computer and see if the error is resolved.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jebrelayoub 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 103
