跳转到主内容
提供自从1986年发布的大部分游戏机 拆解和组装指南。
16181 个问题 查看全部
insulation on wires is falling off Guitar Hero Drums
On my Guitar Hero drums, how can I replace the wire from the drums to the foot pedal? The insulation is cracked and falling off.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Not a believer in throwing $ at the problem, unless it is the only option. Subsequently contacted Activision to see what they have to say. Will try the headphone cable solution too. Thanks for the follow-up.
完成的
it is hard to change a wire to the guitar pedal,i had the same question like you in the past time,but i went to the physical store to replaced it.which pedal had you bought?i think this one is a good choice!
http://www.baroni-lab.com/tube-heart-dis...
完成的
添加一条评论
4个答案
已选择的解决方案
Of course it's always easier to throw money at the situation; buy a new thing when it breaks and throw the old one away, but that's not what this website is about.
If I recall correctly, that cable is just a headphone cable. You should be able to buy a cheap pair of headphones with a long enough cable, cut the headphones off and solder them to the appropriate points on the sensor.
Of course, after you repair the first pedal, you could buy a second foot pedal and a cheap headphone splitter, and rock both pedals at the same time as a double bass.
这个答案有帮助吗?
得分 4
2条评论:
+ Thank you for telling him how he can fix it. Hopefully the original poster will come back to look at this and accept your answer.
完成的
完成的
添加一条评论
The easiest thing to do is just replace the foot pedal. It would run you $20.00 - $40.00 to replace it OR you can repair it but you'd have to buy the same type of wiring and solder onto the sensor underneath the pedal.
这个答案有帮助吗?
得分 0
7条评论:
Thanks,new foot pedal sounds like the easiest solution.
完成的
I didn't give this enough of a look before. Your Answers should tell people how to fix their devices, not tell them that it's more economical to buy a new one. Our mission is to reduce e-waste, not because it's the cheapest route, but because it's the right thing to do.
完成的
Ok well you would be buying a new headset, you are still throwing money towards the project and not eliminating waste because what good would headphones be with no cable? Nice ear muffs I guess? If you're going to spend money on it, why not just get the part that is needed instead of taking a chance of not even fixing it in the first place?
If you want to eliminate E-WASTE, recycle is the number one solution. Maybe the site should be focused a bit on recycling too. 50% of the stuff we get in for repair is failed repair attempts. We are only able to reach so many people and the people we don't reach throw the consoles away in the trash. Why not make up a way to recycle?
完成的
+ Please post this to www.ifixit.com/meta
Sounds like something they might want to look into
完成的
Reduce first, then re-use, then recycle.
完成的
显示更多的2条评论
添加一条评论
Vynil Electrical Tape
这个答案有帮助吗?
得分 0
添加一条评论
I did it for free - simply removed the insulation sire, you'll need some fairy as it is a bit sticky underneath. Obviously the wire is less protected but if it gets damage there is always that old set of 'unused' headphones in the loft. Enjoy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
maddal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 9,177
