跳转到主内容
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
My computer won't boot, i'm getting a folder with ? on it
My computer won't boot, I'm getting a folder with ? on it. The bottom of the computer seems very hot.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
This might be a disk failure. A specific batch of Seagate disks used in Macbooks have been known to fail. There was an Apple extension program to replace them (http://www.apple.com/support/macbook/hd/...), but it just covered the disk. Try at an Apple Store if you still haven't fixed the problem.
完成的
添加一条评论
4个答案
已选择的解决方案
Your computer can't find an operating system. Try booting with your operating system disk. If successful run drive repair and see if that clears up your problem. If not you may have to reinstall your operating system. If unable to do so you probably have a bad hard drive. Ralph
这个答案有帮助吗?
得分 6
添加一条评论
I would put the install disk in and do a hard ware check. http://support.apple.com/kb/HT1509 there are instructions for that. If the hard ware comes up fine, do a fresh install of the OS. Hint: mine had this same problem and it was the hard drive.
这个答案有帮助吗?
得分 3
添加一条评论
This indicates that some critical OS files cannot be found, or a corrupted OS or maybe even (as mayer says)a HD failure.
这个答案有帮助吗?
得分 0
添加一条评论
Try replacing the SATA cable. It costs about 50 usd direct from foxconn
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jayne Quinn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 3,614
