跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
Replace HDD to SSD iMac 27" late 2015 (model MK462LL/A)
Apple iMac MK462LL-A 27" Late 2015
Dear forum,
I recently purchased an iMac 27" late 2015 (model MK462LL/A). Since the factory upgrade of the HD to SSD was pretty expensive, I purchased a Crucial BX200 960GB SATA 2.5" 7mm (with 9.5mm adapter) Internal SSD. I have the following questions.
I wanted to follow the below tutorial.
iMac Intel 27" Retina 5K Display Hard Drive Replacement
However, the tutorial states that is up to Mid 2015 only.
1)Does anyone know whether there are any changes in the component layout for the late 2015 iMac?
2)I purchased a 3.5" bracket to mounting the SSD. I would like to know whether I should also purchase a OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" ? I cannot find any threads stating Crucial SDD lack of temperature sensor?
3) I also would like to know whether I need to purchase new Adhesive Strips once removing the screen glass?
Thank you very much!
Juan
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi,
I have the same question did you ever find out??
Many thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Juan Galindo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,348
