跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 个问题 查看全部
How to completely wipe all data on my mac?
I am going to sell my old Macbook Pro online and there are some sensitive data on the computer. I want to completely erase the Mac that no one can access the content with some data recovery software. How can I do that?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
If the data is that sensitive and you want to make sure its never recovered remove the drive. even drives that have been zeroed can be recovered . industry standards state to zero a drive 7 or more times to insure no recovery
完成的
thank u for the suggestion
完成的
添加一条评论
3个答案
已选择的解决方案
August's answer is OK. But I would boot it Target Mode or from and external source. Then access the drive with Disk Utilities and use the "write zeros" option and reformat the drive.
这个答案有帮助吗?
得分 3
7条评论:
Then be a nice guy and re-install the OS.
完成的
i didn't have the installation disk.
完成的
You should be able to download from the Apps Store a copy of the OS installer. Copy it over to your external bootable drive you'll be using to boot up from to wipe your internal drive. Then after the drive is clean launch it, install the OS, but stop when it asks for your user information.
完成的
After you have zeroed out the disk, boot it holding down the option key to do an internet system reinstall directly from Apple. You will need an internet connection, wi-fi or ethernet. Ethernet is usually faster.
完成的
And depending on the age of the system, have the newest firmware level so it can do an internet recovery otherwise it will need to use the recovery partition on the drive or an external boot drive as the source of the needed files.
完成的
显示更多的2条评论
添加一条评论
最有帮助的答案
Use the Disk Utility Application in recovery mode.
Use the Erase tool and choose the highest security setting possible.
Then reinstall OS X.
这个答案有帮助吗?
得分 3
1条评论:
...There appears not to be a way to change the security level in the erase tool, any chance of explaining how to find that, map A1278 with o/e el cap. TIA,
完成的
添加一条评论
A single wipe is not secure enough to wipe your mac completely. You can use third-party apps to delete all files on your mac and use disk utility to format the drive. If you turn on Find My Mac on your computer, you can use iCloud to erase data on the Mac.
这个答案有帮助吗?
得分 0
1条评论:
The write zeros option in Disk Utilities can run once or seven times.
完成的
添加一条评论
添加你的答案
oilyardm 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 1,289
