跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Wi-Fi is grayed and No Bluetooth
My phone6 wifi connection is greyed out and blue tooth is not working, I have tried all the method post to web, the problem still not Fixed. look like have need replacement of the iPhone 6 Wi-Fi Antenna replacement.
Can someone tell me is
iPhone 6 Top Left Antenna
had fix the problem using above wifi replacement or any issue.
iPhone 6 Top Left Antenna图片
产品
$9.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The wifi antennae is the first thing I would look into, after that it's like what jump1n said, you'll have to have the board worked on
There isn't a guide for it, now. You're not supposed to use the teardowns as guides. But I do it all the time
iPhone 6拆解
产品
$9.99
这个答案有帮助吗?
得分 1
添加一条评论
I had the same problem and with the iPhone 6 this is a very unknown issue and I researched into it and found this. Something may of come loose connector wise check thembut in setting under wifi address it says NA then yes try those but I reckon it's the wifi chip has benn moved from its place on the motherboard, replace that and it'll be good as new,
Hope I helped
Regards
Lucas
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
hklha 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 554
