跳转到主内容
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428 个问题 查看全部
Machine turns on, no signal / video output?
I have an xbox 360 that has never red-ringed and turns on just fine, but refuses to work with any TV I try to plug it into. I have plugged another xbox 360 into the same cables and TV, but when I plug this one in the TV reads "No Signal."
Any thoughts??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
1条评论
I need help on the same 360, needs laser replacement but its something else now, i go to turn it on and it does but dont fully boot up, tried switching to a different setting but shows no display, whats the problem, its from 12-04-2006 and its the Xenon model with AV cable only, tried the cable on my Jasper model from 2-18-2009 and it worked so idk
完成的
添加一条评论
7个答案
已选择的解决方案
Make sure that the component cable is set to whatever input you have the cables plugged into. For example, if you are using the component connection, RED-GREEN-BLUE and then WHITE-RED for your audio, make sure the switch is set to HDTV. If you are using standard connection, YELLOW-WHITE-RED, then make sure it is set to TV.
If this still doesn't work, try a different pair of video cables and if the same results are coming up, you will need to have the board repaired. You can not just replace the motherboard either or you will not be able to play games on the system, make sure to have the actual board repaired.
Yes there are ways to repair the board out there but board repairs are different from replacing it. If you don't use the right equipment, you pose a greater risk of damaging the board more than it is already. It's best to have the system repaired by a professional that provides a warranty on their work.
这个答案有帮助吗?
得分 3
1条评论:
Who has switchea on cables its not the 70s try again
完成的
添加一条评论
on the video cable, there is a switch that changes between hdtv and standard definition tv. make sure it is on the right one.
这个答案有帮助吗?
得分 2
添加一条评论
This is caused by a heat up of the chips internally and you will need to stop this. The actual chip that is overheating here is the scaler chip or the display chip on the back of the Xbox 360.
这个答案有帮助吗?
得分 2
添加一条评论
If nothing works wrap a blanket around the Xbox while still it's on it will get very hot when it shut it off An back on with hdmi cable on it should work I had to do it for mine
这个答案有帮助吗?
得分 1
添加一条评论
https://www.youtube.com/watch?v=EvFq9-py...
这个答案有帮助吗?
得分 0
添加一条评论
Myxbox turn on, and no signal,everybody please help me, i put 3 wire hdmi and its same. or can i buy the RCA cable?
这个答案有帮助吗?
得分 0
添加一条评论
I've got the same problem
The power is reaching the xbox and i have the green lightturning on but without any image pn the screen
When i took it to the repair shop i was told that the motherboard is blown and there was no solution to that
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hal 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 59
过去 30 天: 236
总计 90,825
