跳转到主内容
加入维修社区 - 创建账户
ZTE Boost MAX N9520 拥有 5.7 英寸高清 IPS 显示屏,支持 4G LTE 和 Android 4.1 系统。
Why won't my external speaker work?
External speaker won't work. Internal work's fine. I can hear music with ear buds, I can hear phone conversation as long as it's not on speaker. My ringer doesn't work as well. Hasn't had any water damage. I did have a cracked screen but it was just replaced profesprofessionally.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi,
How long since it was repaired? Was the ringer function working when you got it back from repair? Does the repairer give a warranty on his work? If it has not worked since his repair (how often do you use the loudspeaker function) it seems very coincidental, contact the repairer and ask. The ringer function (not vibrate) uses the loudspeaker so if it is loose or faulty that is probably why both don't work
由完成的
Why no one can hear me but I contacted hear them
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi Faith Randall,
Have you checked the volume setting for the loudspeaker?
Go to :
Menu > Settings > Sound > tap Volumes > slide volume control for Loudspeaker to desired volume.
这个答案有帮助吗?
得分 3
1条评论:
Yes I did check the volume
由完成的
添加一条评论
添加你的答案
mark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 1,573
