跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
iMac 27 inch videocard replacement due to vertical stripes on screen
Hi all,
Since last week i got vertical stripes on my imac.
Apple said its due to the 6970m 2gb failure but my mac is out of warrenty for it. Also for the recall a while ago.
I checked the internet but an replacement would cost me 600-800 usd. Which would not make sense on a 2.000 usd machine of nearly 5 years old.
Do you know if your stuck with the apple card or could you repair this with a dell 6970m card 2gb ram that is only 150-200 usd?
Else it will be my last mac as this is crazy expensive to repair:(
Thanks for your thoughts!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
2条评论
Thanks for the additional info. Have an appointment with the store manager in my city on saturday!
完成的
je sais que c'est un peu tard pour la réponse mais je donne la réponse pour ceux qui se trouve dans la même situation que toi. Il faut démonter la carte graphique, nettoyer les résidus de pâte thermique, l'enfourner à 180° pendant 8mn, je dis bien l'enfourner, avec une circulation de la chaleur au dessus comme au dessous. Laisser refroidir remettre de la pâte thermique ou il y en avait et remonter tout ça. Ça marche très bien vu que je l'ai fait, bon courage ;)
完成的
添加一条评论
3个答案
已选择的解决方案
I'd would contact Apple directly on this as I cannot find where the recall has been cancelled and it was still valid last March, 2015, when Apple published this: https://support.apple.com/en-us/HT203787
See if your serial number qualifies:
The last four characters of the serial number must contain one of the following groups (for example, xxxxxxxxDHJQ):
DHJQ, DHJW, DL8Q, DNGH, DNJ9, or DMW8
DPM1, DPM2, DPNV, DNY0, DRVP, DY6F, F610
这个答案有帮助吗?
得分 4
6条评论:
Hi!
Thank you for your answer. My serialnumber is on the list you mentioned.
I will try contacting apple again. They first responded that my four years expired 6 months ago.
But as this is a faulty card i will ask them to replace it for free or for a small fee as this is a manufacturing issue.
Thanks.
Tim
完成的
Tim, if you have to, ask for senior advisor. Mention the term "warranty exception", that failing mention the class action law suit. After all it doesn't come out of their pocket but the GPU manufacture's.
完成的
Please keep us informed as to your experience with Apple. This could help others.
完成的
This really helped me out as I just started having this problem on my 27" imac, five years after original purchase. The genius bar people were not able to help but a call to apple allowed a warranty exception code to be added to the case, and I'm getting it repaired for free now. Great to have this answer here. Thanks.
完成的
ianj That's good to know. Mind if I ask where you live?
完成的
显示更多的1条评论
添加一条评论
Hi mayer,
They first told me to pay the full amount.
If they do they do that dont agreeand mention mayers tip.
In the end they offered me 80% discount. That was the best I could get after a long comversation.
这个答案有帮助吗?
得分 2
添加一条评论
Having the same issue with my IMac. I just came back from the apple genuis bar and as expected, they can't do anything. Giving a call monday in order to see if they can do it for free. Mayer, you were saying that i have to mention de term warranty exception? was there a class action lawsuit aswell?
这个答案有帮助吗?
得分 0
1条评论:
Samuel, how did this go for you? My iMac just showed this a couple of months ago and now it won't turn on.
完成的
添加一条评论
添加你的答案
Tims 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 7,370
