跳转到主内容
A laser printer series by HP for home and office use. These printers often have problems with the formatter board.
17 个问题 查看全部
Why printer goes direct to ready mode on startup and not printing
my printer is indicating ready always on start up without indicating on other functions and is dormant. what is the problem and how do i solve it?
Update (01/15/2016)
why is the printer showing the ready button only on statup
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi,
Try a cold reset of your printer
Use the following procedure to perform a cold reset.
1. Turn off the printer.
2. Press and hold the Go button.
3. Turn the printer on, and continue to hold the Go button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED turns on.
4. Release the Go button.
NOTE If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1.
The printer's LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
A cold reset changes most system parameters in NVRAM to the factory defaults. A cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
NOTE A cold reset also resets all the HP Jetdirect settings as well as the printer settings.'
这个答案有帮助吗?
得分 3
1条评论:
dear :sir
thank you for your co-operation
i do the cold rest steps but the printer still as before. but still the ready led still on
edrees
完成的
添加一条评论
添加你的答案
john mburu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 768
