跳转到主内容
Repair guides and support for phones manufactured by BLU Products. BLU stands for 'Bold Like Us.'
1766 个问题 查看全部
Blu Dash M Sim Card
Hello,
I have a Blu Dash M and I just received the Tracfone activation kit but the sim card is smaller then what the sim card hold is. Is this correct?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Thanks. Will try this! Also, the tracfone activation kit came with a card with the bigger sim card in it which I punched it out but then it was in another card which I punched it of of that also since it wouldn't fit into the phones slot. Do you think I can just put that second card around it and try to fit it into the phone slot? It did come with a mini sim card so if I just use that will that be okay?
完成的
Yes, put the second ring you punched out back around and it should function normal. Just make sure it doesn't slide out of it and gets stuck.
完成的
添加一条评论
1个答案
已选择的解决方案
You can buy little adapters online for smaller sim cards to fit in bigger slots.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
anitadassenko 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 249
