Thanks. Will try this! Also, the tracfone activation kit came with a card with the bigger sim card in it which I punched it out but then it was in another card which I punched it of of that also since it wouldn't fit into the phones slot. Do you think I can just put that second card around it and try to fit it into the phone slot? It did come with a mini sim card so if I just use that will that be okay?
2条评论
由 anitadassenko 完成的
Yes, put the second ring you punched out back around and it should function normal. Just make sure it doesn't slide out of it and gets stuck.
由 MisterMisterious 完成的
