Can I replace my headphone jack?
The headphone jack (located below the power button) on my PPC G5 is damaged.
Can I repair or replace this part myself?
Get an extension cable for your headphone and use the rear port. You can replace the panel. Here's the part on eBay: http://cgi.ebay.com/G5-PowerMac-case-Par...
Here's another: http://www.welovemacs.com/9225979.html
UPDATE: Removal
Using a jeweler’s flatblade screwdriver, pry up the metal cap covering the front panel board EMI shield.
Using a Phillips screwdriver, remove the two front panel board mounting screws.
Carefully pull the board a short distance out of its EMI shield, and disconnect the power button cable from the board.
Remove the board and shield from the enclosure. That's it.
See page 75 of Apples Power Mac G5 Take Apart: http://www.baconeggs.co.uk/images/dmm/po...
这个答案有帮助吗?
level and tool set. If you feel uncomfortable soldering logic boards take it to a computer repair shop.
'''If this answer was helpful please remember to mark it accepted.
Good Luck,
N
这个答案有帮助吗?
Thanks so much for the assistance.
The G5 PowerMac case Part FRONT PANEL USB FIREWIRE BOARD referenced by rj looks like what I need.
Can I access and easily knock out the old part? In other words, is this a simple operation like plugging in an HDD or RAM, or is this part difficult to access?
这个答案有帮助吗?
Hi, To give proper credit mayer provided the link for the panel. I will however leave you a link for the service manual. Hope it helps. Ralph
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 3,230
