跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Battery percent does not increase
When I charge my Iphone 6S, the battery is charged but it does not show in the display.
If I shut the phone off and then restart it the percentage "jumps" to the right level.
How do I fix that (I have the latest IOS)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Battery recall program:
https://www.apple.com/support/iphone6s-u...
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
There seem to be a lot of different opinions on how to solve this issue, some easier to try out than other.
First of all, go into settings and turn off "show battery in percentage", then reboot the phone, recharge it and turn on "show battery in percentage".
Some say you need to calibrate the battery. This is done by fully discharging the phone, to the point where it turns off by itself. Then charge the phone to 100% and then discharging the phone again, without tuning the phone off for the entire period. However, I am not sure about the effectiveness of this method, but it is easy to try.
You could try and restore the phone to factory settings, to see if this elleviates the issue.
Now onto hardware issues.
If none of the above fixes solves the issue, you need to replace the battery. As you have the phone open, you can check for missing components around the battery connector - epscially the FL11 shown here:
Last resort would be to change the dock/charging connector.
Hopefully one of the points above will help you solve the problem.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Nils Edlund 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 1,498
