跳转到主内容
Repair guides and support for hand propelled wheeled devices used to move heavy loads.
2 个问题 查看全部
removing bolts to replace handles
I would like to replace the wooden handles on a steel 6 cubic foot wheelbarrow. There are 4 bolts that run thru the bottom of the pan into the handles. They have bolts with slightly domed tops and secured with half inch nuts. The threads are somewhat rusty. When I try to remove the bolts the whole units just turns. The top of the bolt just spins in the hole. I'm considering super glueing the bolts in place but that just doesn't seem right. How do I remove the bolts? If I can get them out, do I replace with more wood handles or look for fiberglass?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi Richard, I would apply penetrating oil to the nuts and then using a chisel clear out a small area by each bolt top. Clamp vise grips tightly to the tops of the bolts and use a "johnson bar" to increase leverage on turning the nuts. If you can't remove the nuts that way I would remove some more wood by the head of the bolts and hacksaw them off. Once removed I would use new hardware and fiberglass handles.
这个答案有帮助吗?
得分 3
1条评论:
完成的
添加一条评论
Don't know if this is still a problem, but I've tried to illustrate a way to remove the bolts.
My suggestion is that you drill into the top of the bolts to remove the tops. Maybe by using a smaller drill to start with.
... but if you are replacing the handlebars, then why not remove all of the wood to be able to get a firm grip on the bolts, and either succed with unscrewing the nuts or hacksawing the bolts(?)
这个答案有帮助吗?
得分 1
4条评论:
+ thanks so much for the drawing and the trouble you went to. I hope you stick around to help with more questions.
完成的
you're wellcome. I've noticed the "+" are they "thank you"s?
完成的
See the 131 under your name? That's positive reputation you've earned from others voting up your answer. If you click on Users in the menu bar you can find the reputation of other contributors. You can then click on their icon to see how they've progressed over time. Check on yours too.
完成的
so some of you put in a "+" when you vote up an answer or question? Nice and thanks.
完成的
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 48
总计 5,230
