跳转到主内容
加入维修社区 - 创建账户
想自己动手修 iPhone?这里有免费维修指南、原装品质的替换件和专业工具,一应俱全!无论是新款 iPhone 17 系列,还是 2007 年发布的初代 iPhone ,iFixit 为所有型号提供免费拆解指南和维修资料!
Secret Code for Display Test
Hello there,
can anyone help me?? Dis Apple had a secret code like Samsung (*#0*#) ??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
1条评论
No it doesn't, because it's a cheap made chinese brand with 60Hz display and 3200mAh and times are rough, we can't add a fast charger of ...drumroll 18 Watts ...because we are saving the planet..
Whilst soldering ram, ssd for the past 5 years...and making flimsy too short backlight cables in 400€+ laptop panels and butterfly keyboards that stick like butter.
Running the company as a beancounter gets you trillions!
Bless c.r.Apple! :)
完成的
添加一条评论
6个答案
已选择的解决方案
Nope there is no secret code to test the display.
You can use an app to test the screen however.
这个答案有帮助吗?
得分 9
4条评论:
Apple iphone secret code please
完成的
@ikhlaq there is no secret code!
完成的
yes their is
完成的
I have seen this code used. And it worked. *#21#
完成的
添加一条评论
You can check your screen either the panel is replaced or not by comparing your iphone to another which you think is genuine.
这个答案有帮助吗?
得分 3
1条评论:
How do I test my screen because it’s not working properly i11 pro max
完成的
添加一条评论
Hello: No secret code. However, the link to the APP for a screen test is in the iTunes store. As of August 23rd, 2017 you have Version 4.0.
https://itunes.apple.com/us/app/touchscr...
You can test the pixels, touch, pinch, move, multi-touch on 6s and beyond.
Remember, aftermarket replacement screens DO NOT provide the moisture seals, response, and drop performance so please use Apple Care or a Certified replacement brand such as eVero. Your iPhone is worth it.
Enjoy, have fun.
这个答案有帮助吗?
得分 2
添加一条评论
Apple uses a special factory firmware called SwitchBoard to perform factory calibrations. It is NOT possible to install it without factory or service center tools, so there is no code to stare test mode because it is likely never there on retail devices in the field.
这个答案有帮助吗?
得分 1
添加一条评论
Apple iPhone secret codes
https://mobilespecs.net/phone/codes/Appl...
这个答案有帮助吗?
得分 1
添加一条评论
Smartphones secret codes and other hidden functions
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Selvan 将永远感激不已
浏览统计数据:
过去 24 小时: 18
过去 7 天: 123
过去 30 天: 524
总计 268,821
