跳转到主内容
Updated in March 2008 with 802.11n Wi-Fi support, the AirPort Express A1264 is a compact and portable wireless network device.
12 个问题 查看全部
My unit just quit working.
Does anyone know how to open the unit without destroying it? Once I get it open does anyone know any common problems these units have?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Perhaps this will help you.
http://www.vonwentzel.net/ABS/Repair/ind...
这个答案有帮助吗?
得分 1
1条评论:
+ excellent
完成的
添加一条评论
最有帮助的答案
The rubber bottom comes off and there are four screws. Problem is what to do after it's open. Are you getting any power to it? To open my power adapter I ended up taking a hammer and hitting it over a dozen times(This baby is tough). After opening I really found no user replaceable parts and ordered a new one in from China. It took 18 days to get, but I now have a working Airport.
这个答案有帮助吗?
得分 1
6条评论:
完成的
I think you are talking about a different unit. My unit is about the size of a laptop power supply and has an Ethernet port, a USB port and a speaker port. I used it for a printer on the network or a set of exteranl speakers. It is called an Airport Express base station. There is no rubber bottom.. as stated earlier, looks like a laptop power supply (3"x 3-3/4" x 1-1/8").
完成的
The bottom of mine say "Airport Extreme Base Station". My error, yours is the Express. fj713's link is excellent.
完成的
To quote vonwentzel "there is little one can do inside the Express, anyway, as every component is integrated right onto the mother- or daughter-board. There are no more separate transmitter cards, jacks, etc., so there really is no reason to open the Express besides curiousity and the desire to void the warranty as quickly as possiblthere is little one can do inside the Express, anyway, as every component is integrated right onto the mother- or daughter-board.
完成的
from China? can you give as the source?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 5,405
