跳转到主内容
加入维修社区 - 创建账户
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
问题已关闭
Bad Sector
After running Smart Utility i got a "FAILING' result. It says it has "realocated bad sectors". This is a new machine and im not even using 20% of drives capacity and I dont have many apps at all on this machine. It has barely been used. What could the problem be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hard drives can and do go bad at any time. In my experience they usually last a good long while, but occasionally you'll get a bad one. The bad ones can fail at any time no matter if they are new or old. Those kind of utilities do sometimes give false positives though so you might want to get a "second opinion" with other software diagnostics, or repeat runs of the same one.
Since your machine is new, the hard drive will be covered by apple so I would recommend you take it in to the apple store and let the techs run their own diagnostics. They should be able to confirm or deny the problem. If there is a problem then they will repair it for free (assuming you haven't already voided the coverage somehow).
If that's not an option then you could just replace the hard drive yourself. They are pretty cheap these days and in your model it's easy to do yourself:
MacBook Core 2 Duo Hard Drive Replacement
If that doesn't appeal to you then you could take a more cautious approach. Keep your data fully backed up all the time, and regularly run the diagnostic to see if the problem seems to be getting worse, all the while keeping an eye out for other problems like random crashes. If it's clear that it's dying then just replace the hard drive.
这个答案有帮助吗?
得分 2
1条评论:
Yeah, i believe its a false positive because disk utility has Verified the drive with no bad sectors or failures. Thanx for the feedback, appreciate it.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 1,177
