跳转到主内容
加入维修社区 - 创建账户
包括 Apple Watch、搭载 Android Wear 的手表、Fitbit 等在内的各种可穿戴设备的综合指南与支持。
Why I can't reset my password?
I was forgot my smartwatch password and now i can't use it it's GT08 smartwatch
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 86
25条评论
How I will return it back please answer me
完成的
Thanks for helpful information :)
完成的
how to reset noise smart watch
完成的
My smart watch is model RYX-NX9 HOW Can I get its puk
please help
完成的
Hello I got a Chinese smartwatch the V8 and I forgot My password.
Is there any wat to reset it to the factory code?
Thx
完成的
显示更多的20条评论
添加一条评论
22个答案
已选择的解决方案
If you haven't changed it yet, the factory set password is "1122". If you did have a password and forgot it, you may want to factory reset your watch.
Hope this helps.
这个答案有帮助吗?
得分 58
46条评论:
Its not working
完成的
Who well Doctor it and there ie password
完成的
How well factor it and there is password
完成的
How do you perform a factory reset on this particular one, I have one with the same issue and would like to just factory reset back to like it was when I first got it but can't remember what I did with my instructions manual. Any help would be nice, I've searched the internet and still can't find anything.
完成的
I need help with the same thing
完成的
显示更多的41条评论
添加一条评论
Simply remove the battery
Wait for some minutes
Insert the battery again
Switch on and type in factory set password - 1122
Problem solved!
这个答案有帮助吗?
得分 17
13条评论:
Can u help? I had already set connectivity and network but still can't download apps. Pop up Browser.... would you like to download and install... I clicked Install but did'nt work
完成的
connect it to computer and try from google apps store more likely it works you can download and install or uninstall from google android apps. hopefullu it works, Nest of luck.
完成的
it still say wrong password
完成的
it is off when i have on it the smart watch that it asked password. input phone password
完成的
it doesn't"t work
完成的
显示更多的8条评论
添加一条评论
i have smartwatch zd09 i forgot my pass word which i type 1122 factory reset pass word i used but cant can you help me to solve this prob
这个答案有帮助吗?
得分 10
1条评论:
Please help me...I sell smartwatches I sell a search Z36 brand new I have never tested or connected it to my phone before. But why showing customers a wicked customer must have put in a password,I cant remember who it is,I cant unlock my the password and I have never commected it to my phone. How do I reset it so I can sell it please
完成的
添加一条评论
Switch on and type in factory set password - 1122*
这个答案有帮助吗?
得分 9
4条评论:
Restart pass word 1122
完成的
Restart pass word 1122 Thanks
完成的
The prescribe password ie.1122 which i enter is denoted as incorrect password. Please help
完成的
I have the same ... :( and after Putin ing 3 times a pin code, it switch off by itself. What to do
完成的
添加一条评论
the code is 1122 (factory)
这个答案有帮助吗?
得分 6
4条评论:
no i change my password and when i turn it off i dont remember the password
完成的
I have bought a dz09 smart watch and it as enetered password recently and he don't told me the password kindly told me any way way to Hard Reset my watch.
Kindly tell me as soon as possible.
完成的
dz09 go to the dialer ( as if you was going to make a phone call and enter this to restore the phone and reset the password ....Restore factory settings: *#987*99#
完成的
I have foxwear camera watch. It is working in LAN mode(local mode) but when I try WAN mode then APP(sysm monitor) needs password. That password I can not find ??? The leaflet which I have received with camera watch has some passwords but none of them are ok for remote access.
完成的
添加一条评论
i have been having much issue then i went on you tube n figure it out first you get the password screen with 3 trials i type in 1122 then i hit ok its going to say wrong password at this point it takes you back to the password screen where u have 2 trials left i type 1234 then hit ok and its going to again said wrong password i type 1234 again n it said done meaning it work SHOCKING but it work i have been messing with this phone now for a week hope it work for u guys i have the DZ09 Smartwatch with the copperface thnaks
这个答案有帮助吗?
得分 4
3条评论:
How didi you do it? I have the same watch. I kinda forgoten my password too. Pls help me. Thanks
完成的
完成的
Wrong password
完成的
添加一条评论
1122 is default password, unless you changed it then forgot it; I don't think there's any way of recovering it unless you use PC Software (If there are any for this, which I don't know yet) but I just got the smart Watch and 1122 worked as default password for Watch Lock Security.
这个答案有帮助吗?
得分 2
添加一条评论
no keyboard no alpha , just numbers
这个答案有帮助吗?
得分 1
添加一条评论
Hey guys, I had this issue where I couldn’t reset the Spacetalk series 1 due to not knowing what my password was - I eventually found that it is the last 4 digits of the IMEI number, this can be found if you go into the information tab on the watch - hope this helps :).
这个答案有帮助吗?
得分 1
添加一条评论
My watch is watch 7 model W26+.please help me itbis locked
这个答案有帮助吗?
得分 1
添加一条评论
I recently bought a smartwatch watch dz-09 but when i wanted to restore factory settings,the default password did not work(1122).What can I do pls help
这个答案有帮助吗?
得分 1
添加一条评论
I forgot my password what to do anyone help
这个答案有帮助吗?
得分 0
添加一条评论
I need help with trying getting back in my smart watch i recent forgot my password Nd I can't get back in my smart watch
这个答案有帮助吗?
得分 0
添加一条评论
What do i do when i forgot my username and password?
thanx
这个答案有帮助吗?
得分 0
添加一条评论
I tried 3 times, first 1122, 2nd 1234, 3rd 1234 but Pass word
这个答案有帮助吗?
得分 0
添加一条评论
That don't work what I should
这个答案有帮助吗?
得分 0
添加一条评论
recently just purchased this smart watch for my husband as well. as soon as we turned it on it asked for the phone pass code. so reading the owners manuel i saw the code 1122 , we entered the code and still nothing. I’ve tired codes 0000 , 1212 as well as 1234 and still nothing. there is no way to bypass this screen. the smart watch gives you 3 tries to enter the pass code once you enter the pass code the third time the smart watch shuts off.
这个答案有帮助吗?
得分 0
1条评论:
I'm having the same problem
完成的
添加一条评论
input phone password for W008
这个答案有帮助吗?
得分 0
2条评论:
I do not have a keyboard when I type in a password, only a number board. So I cannot type in the W
完成的
I have a GT08 I can’t the i can’t bypass my password
完成的
添加一条评论
I cant get in to the watch i tryed 1234 and1122 but they didnt work i got the watch from a pawn shop bit no luck on findimg the password
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
3条评论:
完成的
完成的
I have T500 pro when i reset it and go for putting password again it asks wrong password.I tried different passwords to set but it asks wrong password please help me.
完成的
添加一条评论
I have Z3 hottech smart watch i had put passcode ,but I forgot how do I reset it again ,I tried 1122 but still showing wrong passcode can you please help to reset it
这个答案有帮助吗?
得分 0
添加一条评论
I have type in the code but still is not working 1122 and 1212 plus 1234and also 0000
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Farid Hamdy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 21
过去 30 天: 91
总计 118,134
