跳转到主内容
加入维修社区 - 创建账户
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
MacBook Pro won't turn on and charger is dim green?
Okay, so, my trackpad stopped working. Then, the light on the front of my macbook would come on when I closed my mac, but when I opened it, the light would go off. I then shut down my mac and it wouldn't turn on. So I unplugged the battery, plugged it back in, and did the whole 10 second trick (I already know that) and it still won't turn on. So now, my charger shows a dim green light when plugged in. Also, with the battery lights on the side, there is 1 on, it's not even flashing, just on.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
Unplug your trackpad from the motherboard then try to startup, see what happens.
完成的
Thanks but I just tried that, didn't work.
完成的
i suppose that you already did SMC and PRAM reset right? it help with such issues.
good luck
完成的
添加一条评论
1个答案
已选择的解决方案
Check the pin out on the Mag-Safe adapter, here's the voltages on the right: https://en.wikipedia.org/wiki/MagSafe
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Justin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 2,532
