跳转到主内容
加入维修社区 - 创建账户
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Will not load operating system...
Our Mac Pro 5 powers up, but will not load the operating system. It gets stuck on the grey screen with Apple logo, and appears to be loading. After a few minutes it powers off, and re0boots, continuing this pattern until i manually hold the power button down to power off. Please help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Your hard drive may be fouled up, or your OS is severely corrupted. Try booting into safe mode by holding the Shift key as soon as you boot up. If you are able to Boot properly in safe mode, check your Hard Drive using disk utility and make repairs if necessary and immediately reboot. This failing, get back to us.
这个答案有帮助吗?
得分 3
2条评论:
+ If it will boot from the System DVD, then Majesty is correct.
完成的
agreed with mayer's caveat +
完成的
添加一条评论
install another harddisk and put a fresh osx install on it. Then migrate your data.
that if it's the harddisk.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Erin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,136
