跳转到主内容
Second version of the Beats pill. Sold by Apple in California. Released in 2013. Model number: BO513.
20 个问题 查看全部
The microUSB port to charge my pill is broken.
The USB port to charge my pill is loose. Can it be fixed, if so how?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
4个答案
已选择的解决方案
Here's parts...
https://www.google.com/aclk?sa=L&ai=CLZ0...
This appears to be labor
http://m.youtube.com/watch?v=4LS3ZSpT2Ug
Basically your charging port is worn out, and you need a new one. It can be soldered back on. If you're willing to do the work
这个答案有帮助吗?
得分 2
2条评论:
explain how i do this
完成的
You'll need to remove the logic board, then desolder the bad charging port, then solder the new one back on. Didn't realize the video I posted was so terrible
完成的
添加一条评论
Lauren mail in your beats pill and will solder the part in for you grios.g3mobile@gmail.com
这个答案有帮助吗?
得分 0
添加一条评论
Don't be fooled by the parts, I bought parts similar from eBay & it was not compatible.
这个答案有帮助吗?
得分 0
添加一条评论
https://www.youtube.com/watch?v=fNGB8KVa...
try this
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lauren Bellamy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 20,005
