The microUSB port to charge my pill is broken.
The USB port to charge my pill is loose. Can it be fixed, if so how?
Here's parts...
https://www.google.com/aclk?sa=L&ai=CLZ0...
This appears to be labor
http://m.youtube.com/watch?v=4LS3ZSpT2Ug
Basically your charging port is worn out, and you need a new one. It can be soldered back on. If you're willing to do the work
这个答案有帮助吗?
explain how i do this
You'll need to remove the logic board, then desolder the bad charging port, then solder the new one back on. Didn't realize the video I posted was so terrible
Lauren mail in your beats pill and will solder the part in for you grios.g3mobile@gmail.com
这个答案有帮助吗?
Don't be fooled by the parts, I bought parts similar from eBay & it was not compatible.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 20,040
1条评论
https://www.youtube.com/watch?v=fNGB8KVa...
由 nicolasb 完成的
