跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
904 个问题 查看全部
Why does the Apple logo flash on and off?
My Ipod 160gig Classic does not boot up. Instead, I see a while 'apple' with a black background flashing on and off. I've charged it and sometimes the menu will appear but it does not play.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Thanks for your replies. The iPod still does not work. I'm thinking it could be a battery problem and have ordered a battery but it could be another problem.
Doug
完成的
添加一条评论
4个答案
已选择的解决方案
My Ipod 30gig Classic does not boot up. Instead, I see a while 'apple' with a black background flashing on and off. I've charged it and sometimes the menu will appear but it does not play.
这个答案有帮助吗?
得分 2
添加一条评论
Here's how to fix it: http://support.apple.com/kb/HT1363?viewl...
这个答案有帮助吗?
得分 2
1条评论:
Doesn't work with flashing Apple. Why just post cut-and-paste replies w/o reading what the problem is> It didn't say "flashing battery icon" or message, it clearly states flashing *apple*.
完成的
添加一条评论
Hi Doug, I'm having the same problem. Reseting, or trying to put the I iPod into disc modus didn't help. Did you have luck changing the battery?
这个答案有帮助吗?
得分 0
添加一条评论
Yes. It turns out that a battery replacement was needed. Apparently, my car, a VW RAbbit, constantly charges the ipod. My thinking is that this is hard on the battery which lasted only about 2 years.
Good luck!
Doug
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Doug 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 39
总计 37,407
