跳转到主内容
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 个问题 查看全部
Confused on how to transfer data from old HDD to new replacement?
I am getting my moms old macbook pro from June 2009 and I'm going to use it for school.
The hard drive is getting old and is about to fail so I want to replace it but am confused on how to get the boot files and everything to the new drive.
Could I just buy an external drive and a new replacement drive and use Carbon Copy Cloner to move everything from the old hard drive to the external one and then install the new replacement hard drive and use the external drive to boot up the computer and then copy all of the files from the external to the new hard drive in the MBP?
Sorry I am a bit confused with this stuff.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I think you're making this harder than it is ;-}
First you'll need a means to connect your new drive to your system. If you can locate a FireWire case to hold your new drive it will be the faster way or you'll need is this: SATA to USB 2.0/3.0 Converter for SSD / HDD.
Before you start you should make sure your firmware is up to date follow this Apple T/N: About EFI and SMC firmware updates for Intel-based Mac computers. If you can backup your internal drive to an external drive this would be a good time to do it (if you think the drive is about to fail). If you can using a different system see if you can prep the drive up as I outline below so you can use it to do diagnostics of your current internal drive.
Download from the Apple Apps store the OS installer onto your still working HD El Capitan. I do recommend making a copy of the OS installer as during the installation process it will be erased.
Now connect your new drive to your system and open up Disk Utility you'll need to create a GUID partition map and create a Mac OS Extended (Journaled) partition. Once done you can then launch the OS installer and select your new drive to install the OS. Create a new user account (different from what you currently have. At the end of the process you will be asked if you have anything that needs to be migrated from another system in this case select your internal HD and the installer will launch the Migration tool and copy over your current user accounts, apps & data over to your new drive. It will also mark off what apps need to be updated.
Once done you should be running from your new drive, if you are using the USB adapter it will be slow! So don't panic! Once everything is OK shut down your system and swap out your HD's and you're done!
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Tom Hutchery 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 388
