跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
Replacing Trackpad - Tri-wing size?
Greetings all,
I'm replacing a cracked trackpad on my A1278, per Ben Eisenman's instructions here.
I do not own a tri-wing screwdriver or appropriate bit, and I wanted to make sure I ordered the right one(s). The six tri-wing screws on top seem to be significantly smaller than the tri-wing height adjustment screw, and I wouldn't think that the same size bit would work for both.
Could someone possibly confirm the sizes of these heads? Would the tri-wings from the 54 Piece Set, #0 and #1, be sufficient?
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
yes
这个答案有帮助吗?
得分 3
1条评论:
Sad to say that the #0 tri-wing bit was not small enough for the six screws affixing the trackpad to the aluminum body. It was only sufficient for the height adjustment screw.
完成的
添加一条评论
@mayer
if #0 was not small enough, how did you remove the six screws?
这个答案有帮助吗?
得分 0
添加一条评论
Waiting for my Tri-wing screwdriver to arrive. In the meantime I used an open side of my tweezers to slowly but successfully unscrew each of the tri-wing screws holding in the battery. Not recommended, but worked in a pinch for a client.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kyle Miller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 7,401
