跳转到主内容
加入维修社区 - 创建账户
BLU Studio 7.0 II 是一款无锁 GSM 智能手机,配备 7 英寸、600 x 1024 分辨率的 LCD 显示屏,运行 Android 5.0 Lollipop 系统。这款平板手机于 2015 年 8 月发布。
Camera doesn't switch to rear camera
My option to switch the camera to the rear isn't there anymore and on snapchat when I try to switch it doesn't work. How do I fix the camera to where it will switch.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 30
15条评论
Have you ever figured it out yet? I'm troubleshooting a friends BLU Studio 7.0 II as well and am experiencing the same problem. In the camera app and anywhere involving the camera, I'm unable to switch to the rear facing camera. The little icon to switch camera's (which shows in the owners manual Audrey sent the link for) does NOT appear. They told me that at one point it WAS working properly and it clearly has the hardware of a rear camera. I tried backing everything up and factory resetting it and nothing. Please help!
由完成的 分享
Yes my problem is long fix and gone I was able to make someone in the electronic department open it up and attached a wire which was loose and it works perfectly
由完成的 分享
Hello I also dropped mynphone ! Camera stop work infromt! I also open it see the micro camera slip PFF the connecting pad !to easy to fix! Just press it back into place robot is from restart not reboot!!!!!fixed
由完成的 分享
my blu advance 6 camera wont turn on at all. i guess this message once i try turning the cam on 'cant connect to the camera. please make sure to close other apps that may use camera or flashlight.' and prior to that i noticed that i somehow lost my flashlight app. HOW CAN I FIX THAT PLEASE?
由完成的 分享
Why doesn't my back camera work I have the front camera work good but the want to flip to the back camera
由完成的 分享
显示更多的10条评论
添加一条评论
5个答案
最有帮助的答案
Here is the online manual to it, it should give you some help: http://www.manualslib.com/manual/913783/...
这个答案有帮助吗?
得分 2
2条评论:
It didn't work. I've already tried all those options plus doing a manual reset
由完成的 分享
Try turnphone off back on not reboot!!!
由完成的 分享
添加一条评论
I lost the ability to use my rear-facing camera one day when I dropped it that had been Maybe 4 months ago from August 2016, so when I dropped it this time in August 2016 I decided I wanted to see the battery when I took the whole back off and put it back on and noticed a little computer piece was broken off and out I took the back back off of it the phone, and snapped it back in and noticed that that piece was actually right behind where my rear facing camera was. I turned my phone back on and Wawa I have my rear facing camera again so to everyone who can not use a rear-facing camera I suggest you take the back off of your phone to where all the computer parts and see if there is a round black thing behind your rear facing camera if not it must have fallen out when you dropped and cracked it open
这个答案有帮助吗?
得分 0
4条评论:
This is also a Blu Studio 7.0 Blu Studio II 7.0
由完成的 分享
I have the same problem my rear camera icon disappeared
由完成的 分享
Me to I didmdrop my phone to!
由完成的 分享
Oops imeantnback camera not front !to easy to fix!!!! Openup phojensnapmbaxk onto pad
由完成的 分享
添加一条评论
I took my camera off of HDR in the camera settings.
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
1条评论:
Hey guys I was able to get someone in the electronic department open it up and attach a wire that was loose and it's working perfectly right now
由完成的 分享
添加一条评论
Sometimes camera might not work for some glitches and it can be easily fixed by restarting your phone. I had the same problem with my new BLU F91 5G mobile but it's now fixed.
Please do it and that's easy.
If it doesn't fix the problem then you will have to reset your BLU phone, that's the only option left.
Still the issue is not fixed then please contact BLU if the phone is under warranty.
Finally if it's not under warranty then you can't do anything except replacing the camera module or chip.
The best thing would be to get a new phone instead of BLU Studio 7.0 II
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
batman42415 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 24
总计 56,710
