跳转到主内容
加入维修社区 - 创建账户
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
iPhone 5 ''Charging'' loop problem
Okay, I've search throughout the web but I can't find a fix for my problem. Here's the situation :
-When I plug in my iphone 5 into ANY power source (wall charger, PC, car charger, etc.) it shows the Apple logo for about 2 seconds then shuts off for about 3 secs, then it shows the Currently charging sign and goes back to the apple logo screen. It's been doing that for about 3 hours.
-I can't make the IPhone show the cable + itunes sign.
-I can put the iphone in DFU mode but that's about it, my itunes recognizes my iphone as an iphone in recovery mode but I don't want to restore it since I didn't save anything so I want to avoid data loss. I might try it if I can't find anything, but that's my last resort.
-My IPhone is about 2 and a half years old.
-I'm currently running IOS 8.1
-My iphone's jailbroken but the loop didn't start just after I installed new packages so I don't think that's the problem.
-I've tried many methods and consulted many treads but most people just have the reboot loop or the blue screen loop, and these solutions don't work for me.
-Wondershare's Dr Fone program doesn't even detect my Iphone.
Thank you in advance for your answers.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The iPhone 5 is pretty easy to work on. Here's a guide
iPhone 5 更换电池
Here's parts
iPhone 5 Battery
Replace a 1440 mAh battery compatible with iPhone 5. 3.8 Volts (V), 5.45 Watt Hours (Wh). Does not require soldering. Compatible with all iPhone 5 models.图片
产品
iPhone 5 Battery
$29.99
这个答案有帮助吗?
得分 2
添加一条评论
A common problem is the battery, take to your local repair shop to have your battery tested.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
glowpixels 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 1,474
