跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
Why won't my I-phone 5c phone charge? It is only 6 mo...old
when i plug my phone in, it does absolutely nothing.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
It should still be covered under warranty...????
完成的
Did you check to see what is inside of the charging port? Sometimes there could be
bug eggs, hair, dust, etc.
That's probably what may be causing to prevent it charging.
完成的
添加一条评论
2个答案
已选择的解决方案
If it's only 6 months old, take it to Apple, you have 1 year of Apple warranty, as long as no one has tampered with it by opening it, you should be fine.
If you have been using cheap charging cables and not original, then you will more than likely have damaged the U2 IC chip on the logic board that controls charging and sync.
I wouldn't mention about cheap cables or anything to Apple, if you have been doing that, they'll refuse to replace or repair it. :-)
这个答案有帮助吗?
得分 3
添加一条评论
Xss (1)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lgraskewicz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 213
