跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
PS4 won't turn on (No light or Beep)
I have had my PlayStation4 since release and just recently it started to give me issues. The PS4 is connected to a working power socket and plug in correctly, however I can't get the PS4 to respond (turn on) in anyway. It won't turn on at all, I get no light or beep like others have. The PS4 won't turn on for the Controller or Disk input. Noting out of the norm changed so I don't understand what would have caused this. No falls, no power outages, no over heating. Any ideas? can this even be fixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 75
66条评论
I also have the same exact problem an I got my game Gta 5 stuck inside
完成的
i have the same problem. i changed the power supply and it did not fix it. when i put in the plug i notice that there is like a winding sound. checked if it was the hard drive but it was that not that either. so now im wondering if something on the mother board is not working for it to not even turn on .
完成的
I can tell uhow to get the game out of the ps4
完成的
I'm having the same problem with mine as well except the eject button beeps but nothing happens. The power button is completely unresponsive and I've tried to unplug it for a few minutes and nothing changes. I have it plugged into a surge protector that is supplying power to 3 other consoles when turned on. So I have power. I don't know own what's going on. Any help??
完成的
my wwe 2k16 stuck inside there
完成的
显示更多的61条评论
添加一条评论
37个答案
已选择的解决方案
I would suspect a power supply issue. If your house has any cockroaches in it then they likely live right inside the power supply. They will cause the power supply to go out. Even if you don't this is still likely your problem.
I hope this helps.
这个答案有帮助吗?
得分 32
34条评论:
I thought that was the problem originally but when I bought a new one it turned on and it shut itself off like the other one and they both had a game in it luckily the second one was already being ejected so I got my game back but there's a good chance it's not a power supply issue.
完成的
Your original question said that there was no response at all (no lights, no beeps, etc.). If your console turns on then back off then it's highly unlikely that it's a power supply problem.
完成的
So if the cockroaches affected the power supply what then? How will I know, what should I do. I cannot open it because of the warrante
完成的
If there are cockroaches in it then you have no warranty. Sony won't touch any console that has insects in it.
完成的
How do you get them out?
完成的
显示更多的29条评论
添加一条评论
Had this problem, tried unplugging and replugging all sorts of things, read through more comments, saw the one about dust, thought "that's dumb, could it really make the whole ps4 unresponsive". Yes, my friends, it can. Blew the !&&* out of all the ports and it turned on. Learned lesson. Don't rule out the dust.
这个答案有帮助吗?
得分 19
20条评论:
So you think just clean the dust?
完成的
Wow you're a lifesaver did just that and it started working again
完成的
MINES HAVENT and i tried
完成的
Do manual eject if there is a disk. Clean out all dust (vacuum external parts and clean with a paper towel. Pop off half the cover and blow into covered part to remove as much dust as possible and wipe down visible dust (all when unplugged). Recover and plug in to direct outlet.
完成的
Just unplugged everything and blew all the dust too and now back on straight away, only had the console about a week too! Was beginning to worry until I read this post! Thanks
完成的
显示更多的15条评论
添加一条评论
The same exact thing happened to me. No joke, seriously just try hitting the top of the ps4 like twice a little hard but not that hard to cause it to break or anything. It worked for me and I tried looking for a way to fix it on the Internet but it just talked about the "Blue light of Death" and that's not what I have. I found no other solution and I tried everything but sometimes consoles and other electronic devices need "a little hit" to work.
这个答案有帮助吗?
得分 14
17条评论:
BRO YOU REALL WERE NOT JOKING. Do "light tap" please don't smack your ps4.
完成的
This 100% worked lol the power just went out for like a second at my house while I was watching Netflix on my PS4 and it would beep, but wouldn't turn on. I unplugged it, took the power cord out, re set the power strip it was on and nothing...then I lightly but firmly tapped the top 3 times and it turned on! Haha
完成的
I just lightly smacked the $@$* outta mine and nothin happened
完成的
Oh, WOW! I just blew really hard into the ports and tried it.....it started right up! Thank you!!
完成的
Lmao no joke it actually worked
完成的
显示更多的12条评论
添加一条评论
The main thing that probably happened with this is if u are one of those people that put your ps4 in rest mode or leave it on long enough for it to turn off its self. If u are one of these people u occasionally when you turn on ur ps4 it says u didn’t turn it off properly. A lot of those messages often can be warning u that the ps4 may crash. This leads to the ps4 not lighting up and may not even beep when any buttons are pressed. I had this problem and all u have to do is unplug the power source from the outlet that it was plugged into and after u plug it back in, you simply hold the home button. DO NOT unplug the hdmi cord from the TV.
这个答案有帮助吗?
得分 6
4条评论:
Thank you human. I am forever in your debt.
完成的
umm i accidently unpluged the hdmi cable
what can i do now
完成的
I unplug everythink while it was on rest mode took with me to work now i have no power how do i fix this ps4
完成的
my ps4 hasn’t turned on in 4 days and i’ve been trying to watch my show😔😔 you’re literally an angel thank you
完成的
添加一条评论
I had the exact same problem, I came here and i did not think it was the dirty (dusty) ps4 issue!
what i did was i took it into the bathtub the following day making sure the water gets right in between the cracks, scrubbing the fker like my life was depending on it, (it is... its my babeh) when it was fully moist in side
i gave it a right blow to clear out any bubbles that might have gotten inside.
after that i let it dry for a couple of days 2-3 NOTE: do make sure the sun hits the ps4 right on the spot.
when the ps4 was dried up i plugged in the power supply and no....it did not work
tip of the day! never take your ps4 with you when you are taking a bath! it does not like water
这个答案有帮助吗?
得分 4
1条评论:
Jerk, knock it off. What are you 12?
完成的
添加一条评论
Same problem. Unplugged everything from the back of the PS4, let it sit for a few mins, hooked everything back up and it's been working ever since.
这个答案有帮助吗?
得分 3
3条评论:
I'm trying everything it did get wet and its not coming on or beeping
完成的
That cannot be fixed
完成的
I just did as you suggested yet my controller flashed a white light and no response from console. I suppose now i need to search what the flashing white light signifies.
完成的
添加一条评论
I faced this problem today. I changed the sockets multiple times, checked for solutions on google but it was no good. My PS4 would not turn on, there would be a beep only when i pressed the eject button. When all hope was lost and I was planning to get it repaired, I brought a disk near the area where you insert it. The disk did not go inside, but the console came to life! So try to put any disk in the console and I hope it will work because it worked for me
这个答案有帮助吗?
得分 3
5条评论:
OMG bro this thing works i had the exact same problem as this guy and if you do too i advise you do this asap
完成的
This worked but does it stay working ?
完成的
This worked!! Thanks
完成的
But i dont have a disk
完成的
It didnt work
完成的
添加一条评论
I had this problem today, i was in a trip and i had to get my power and hdmi cable there cause my friend had the ps4 and forgotten the cables. So i returned and just plugged my ps4 to power as it was before. The ps4 did not turned on at all then i had realized that the power cable (the original cable in the ps4 box when you buy it) is a little loose at the connection point to the console so you have to push it hard and it will just connect (my ps4 is region 2 so the cable is not the fancy region one cable that is made just for ps4 and its a little kind of bad cable. While playing my friend had this problem too its not just when you disconnect it from the power supply
I hope this help you guys
这个答案有帮助吗?
得分 2
3条评论:
I did it and it worked. Thanks!
完成的
My ps4 turned off mysteriously and I tried many things that did not work I tried undusting I even took the top off I used different cords and I blew the $@$* out of the dust but now it won't even beep before it would turn on after my second try to turn on but in a matter of 3 seconds fade out what do I do?
完成的
same here i dont know what to do cant believe this sh&$t again
完成的
添加一条评论
Unplug the power cord and everything else then hold the power button with it unplugged on the console, then it should beep once and then plug everything back in and it should work.
这个答案有帮助吗?
得分 2
8条评论:
mine won't beep with power cord unplugged
完成的
Bro this actually works! I tried everything else above this comment and none of them worked. This one though actually works
完成的
I have tried all of the above. Tried smacking the Ps4 unplugging, dedusting but the machine won't come on not does it beep. Crazy thing is we were playing and poof it stopped switched off while we were playing and won't switch back on. Any other ideas?
完成的
Did you ever find out what was wrong with it cause that's exactly what mine did
完成的
My PlayStation was working lastnight went to turn it on today and no beep or light come on unplugged it change plugs dedusted it pulled it about and still nothing any ideas?
完成的
显示更多的3条评论
添加一条评论
I tapped 3 times and it turned on!
这个答案有帮助吗?
得分 2
2条评论:
this is all you gotta do folks!
完成的
tap where exactly?
完成的
添加一条评论
The power supply provides permanent +5V on its small connector. This +5V is used to power the components responsible for supervizing the power button and giving back the info to the PSU (Power Supply Unit).
When you touch the power button, the PSU is activated and provides +12V on the giant 2 leg connector.
In your case, it seems that the +5V is not produced by the PSU - or - the components powered by the +5V are malfunctionning.
I would first dismantle the PS4 (assuming the Eject button is not responding either), check the +5V with a multimeter, then check for any fuse on the motherboard.
If you find a blown-up fuse, please, please, do not bridge it or you'll fry the motherboard, just report it here and we'll see from there.
这个答案有帮助吗?
得分 1
5条评论:
Maybe you should show them where the fuses are to check.
完成的
yes where would the fuses be?
完成的
Ha ha ha, there are none on the mobo
完成的
Can anyone help me please?When I tried to turn on my ps4 its just no beep or light
完成的
Mine doesnt turn on thers no beep or light only darkness in it and i tried everything to turn it back on
完成的
添加一条评论
I have had issues with my ps4 randomly ejecting discs then it led up to this. I have found that somehow the part that covers the hard drive is squeezing onto the hdd and disc compartment too tightly and it's confusing the ps4. So that means it will keep trying to get the disc out to prevent damage or just not turn on in risk of the disk motion doing rubing or hitting something. I found that if you just take the cover off of your ps4 (the one that just pulls off to show the hdd) that it works flawlessly without further issues. I have done multiple tests trying to figure this out because I kind of like figuring the's kind of things out and more importantly I like my ps4. So just try that and see if it works. It's something with how it's clipped onto the area with the power/eject bottons combined with the added pressure (even as slight as it may be) messes with the intrenal enough to where the ps4 will think something is wrong. I hope this works for anyone having this issue. Happy gaming!
这个答案有帮助吗?
得分 1
2条评论:
Hello so im texting this for my stepmother she has cp and got a ps4 slim for therapeutic purposes. So when she got the game it didn't work at all so she bought a power supply box which helped a little but the game is still not wanting to come on the fan will run but that is it she said if u think you can help please will you email her at wabbie8813@gmail.com
完成的
My ps4 shut down last night, so I unplugged the A.C cord and put it back in it rebooted and everything, and worked fine when I went to bed. But all day today I can't turn it on even with the controller. I've unplugged everything, put it back in and still nothing happens. Even blew on the sides to get the dust out. My power cord is loose and doesn't feel like its plugged in even when it is. Can anyone help?
完成的
添加一条评论
Console won't turn on. Isn't dusty or infested. Replaced power supply and cable. Still nothing. Tried inserting a disc. Nothing. Tried different outlets. Nothing.
I think a power surge is what killed mine. Anything else I can check/replace internal before buying a new console?
这个答案有帮助吗?
得分 1
添加一条评论
I had the same problem. I was playing and it just kept turning off. no light no sound just all of a sudden a black screen and I was cluless. I cannot see how the HDMI could stop post maybe when it's turning on but never stopping it all together. So i waited, I unplugged everything, got a cotton bud and got as much dust out as possible from the intakes and let it stand for a few minutes. It was warm to the touch but nothing worrying. So I turned it on...nothing. I had a radio sitting next to me that ran odd DC and that worked with the power supply so I knew it wasn't that or the socket. So then I went to move the socket and as easy as it could be The PS4 socket was no more than a mm out. So I pushed it in and...boom it worked. So just go through the basics first before you take it down to its individual components.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem most likely one or more of your components in the power supply short circuit and burned out unless you know how to fix components yourself, your best solution is to take it to a game store so they can repair it. It costed me $250 to get it fixed and it took almost 2 months at a crappy game store but it was all worth it. When I plugged in my ps4 I had realized that the HDMI port I had the ps4 connected at the time had burned out too so know I only have one HDMI port
这个答案有帮助吗?
得分 0
添加一条评论
I did vacuumed the dust around it and inside the two holes in the cable. It worked right away.
这个答案有帮助吗?
得分 0
添加一条评论
i had the same problem and just unpluged it pick it up blew out the disk drive and the back vents with my lungs plugged it back in and its now working so im guessing it may have been a little dusty on the inside
这个答案有帮助吗?
得分 0
添加一条评论
Make sure your surge protector or power strip is on people.
这个答案有帮助吗?
得分 0
添加一条评论
Have had this happen to my PS4 multiple times and fixed it every time by: unplugging the HDMI cable from the PS4, keeping the HDMI unplugged, powering on the PS4 and replugging the HDMI cable to the PS4. Have no idea why or how it fixes the issue, but it does (at least for me).
这个答案有帮助吗?
得分 0
添加一条评论
Try moving the ps4 to a sifferent location and plug in the power cord there
这个答案有帮助吗?
得分 0
添加一条评论
Hi guys just faced an issue with my PS4 it was the dust all along my PS4 would make the power noise but nothing would happen so I looked on the internet and it was the dust that was the issue I got my friend to get a garden blower and sucked all the dust out from everywhere and heaps of dust came out then I went to put the power back on and came back on just fine. Thanks
这个答案有帮助吗?
得分 0
添加一条评论
My son and I were playing and the system went black, nothing, nowhere. (I had changed the power supply before with no luck and ended up reballing the chips on the mobo.) So i had an extra power supply and it is up and running. I think the power supply cable gets hot and pliable and works loose and can cause a number of problems, mine had shorted or overloaded the power supply and blew. If they are loose they can get really hot and mess stuff up by not having a sufficient enough supply. Its purring now and I found a good quality power cord that fit snug.
这个答案有帮助吗?
得分 0
1条评论:
What chip pls
完成的
添加一条评论
I had the same problem. It can be 3 Things !!!
1 = POWER SUPPLY ( Look on You Tube how to Identify this one. )
2 = APU Not Seated Properly. ( Send it in for Repairs or get a new one BAD LUCK - THANKS SONY !! )
3 = Full off Dust and overheating. )
Mine was No 3 !!!
Took off covers. Pulled out Hard Drive and Power Supply. Took it in to work and Blew all the $@$* out
of the PSU and Fans and Heat Sink. ( WAS REALLY DUSTY. )
Put it back together and worked fine ever since.
May not be the answer to all the problems but this helped mine. PS... KEEP IT CLEAN !!!. )
HOPE THIS HELPS SOME OF YOU GUYS OUT !!!!!
这个答案有帮助吗?
得分 0
2条评论:
The Power supply in India is in AC, whereas in US or any other foreign country it is DC. Hence you need a DC to AC converter to run the ps4 without any voltage fluctuations.
完成的
No no no all countries use AC is converted by the power supply to DC .
完成的
添加一条评论
Has anyone had their PS4 cutoff with the screen turning white like a bar code and then black? Mine is doing this and powers off. I press the power and eject buttons but no response. I unplug the power and re plug it in. The power doesn’t work but the eject beeps three times. I then press the power and then the system powers on. This happens every 10 mins or so. Any ideas as to why this happens?
这个答案有帮助吗?
得分 0
添加一条评论
Okay. So this is the problem. I was watching tubi TV on the ps4. Suddenly it turns off. The controller is blinking blue. I had dust on it. And I have a mad infestation of cockroaches. So I don't know how to fix it. What do I have to do
这个答案有帮助吗?
得分 0
1条评论:
get a new power supply. $40 on ebay $60 on amazon
完成的
添加一条评论
My PS4 was working perfectly, I accidentally left it running for 30 mins while I popped out, came home and it won’t turn on. Tried pressing the power button still didn’t work, but the eject disc button is beeping every time? Anyone know how to fix? Tried unplugging it, taking the cover off, cleaned all the dust of it n still won’t work
这个答案有帮助吗?
得分 0
添加一条评论
Literally just unplugged mine for the lights then it worked next morning and has been working perfectly since
这个答案有帮助吗?
得分 0
添加一条评论
My fiance anf inwere watxhing movie on it last night and ge was playing games worked fine he went to work came back ans now it wont turn on just beeps there is a disk in it but since it wont turn on cant get it out what might the issue be?
这个答案有帮助吗?
得分 0
添加一条评论
Some PlayStation 4s have this problem. I think this is repairable.
这个答案有帮助吗?
得分 0
添加一条评论
I bought a ps4 had it for a month and it didn’t turn on so I just turned off everything unplugged $@$* changed the stuff a lot and then I said ima just turn the controller on and now it works perfect hopefully this helps
这个答案有帮助吗?
得分 0
添加一条评论
My game watch dogs stuck in there
这个答案有帮助吗?
得分 0
添加一条评论
Tried everything still doesn’t turn on just as I plug it in then it turns on for a second then dies.
这个答案有帮助吗?
得分 0
1条评论:
I had exactly the same problem with my son’s PS4 and I spent a lot of time trying various suggestions about what to do, fortunately the last (and most simple) suggestion was the only one that worked - I blew as hard as possible into the air vents and openings of the unit to clear away any dust build up, I switched it on, and it fired up instantly!, I couldn’t believe it was such a simple remedy. It may not work for everybody but on the forum where I’d seen this tip there were many people saying it had worked for them which is why I tried it.
Hope this works for you…..good luck!
完成的
添加一条评论
Hi Ricardo,
这个答案有帮助吗?
得分 0
添加一条评论
Hi guys …I just got a ps4 from my friend and he said it worked….I took it home and plugged all in and all….it would power on and beep and all…the hdmi was broke so I replaced the motherboard and put paste and all and I went ahead and replaced the power box motherboard too because my old one had roaches in it…I cleaned everything and all….now I plug my PlayStation in and I have no beeps no power or anything all it does is turn the fan on for about a second and stops…..any ideas on what this problem could be???
这个答案有帮助吗?
得分 0
1条评论:
im so sad todday my system shut off completely no light man it also have a electric sound to the back a light vibration but no light after 3yrs waiting to get the funds for another one this happens again plz i know possibly roaches or not i dont know i just so !#^&@@ rightnow
完成的
添加一条评论
I had the same problem days ago, and i fixed it. You will first want to try pressing the disc button bellow the power one and it should turn on, if not, get a disc, doesnt matter if there is already one inside the ps4, try to put the disc in and while doing that press the disc button bellow the ps4. I fixed it that way so hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
Make sure your PS4 is powered off. Plug in and press and hold the power button for 10 secs or until you hear two beeps. This will start the PS4 into safe mode.
这个答案有帮助吗?
得分 0
添加一条评论
Still didn't work.. the console is on and operational too I'm on youtube atm.. the thing is the lights don't work lol idk why but the system works
这个答案有帮助吗?
得分 0
1条评论:
There are some days where I'll trun it on and go to the bathroom and come back to find a system on with no visuals.. only a running motor sound. The playstation symbol did come on the screen as an indicator that things are working. But when I came back to my room the ps4 appeared to be off but the sounds of it being on where still occurring.. so I unplugged it tried it again and I haven't had an issue since.. only on occasions
完成的
添加一条评论
添加你的答案
Ricardo 将永远感激不已
浏览统计数据:
过去 24 小时: 51
过去 7 天: 316
过去 30 天: 1,478
总计 560,227
