跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
645 个问题 查看全部
Compatibilty question for 2009 a1181
I have 2 Macbook 2009 logic boards, I want to build a machine as I have functional 2009 LCD assemblys too. For this will 2006-2008 bottom cases work to put in the logic boards with the lcd assemblys? and the rest?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Sorry guy your still have broken eggs here. These parts are not compatible.
这个答案有帮助吗?
得分 1
2条评论:
sorry the boards are still 2009 a1181 versions
完成的
Lets review again: "For this will 2006-2008 bottom cases work to put in the logic boards with the lcd assembly?" And you are trying to fit: "I have 2 Macbook 2009 logic boards, I want to build a machine as I have functional 2009 LCD assembly too" These parts will not fit or work in the cases. These parts are NOT compatible.
完成的
添加一条评论
No they are not the same, 2006 to 2008 cases are completely different from the Unibody models. They have completely different builds and frames. The LCD's are also not compatible between the two styles.
这个答案有帮助吗?
得分 1
2条评论:
sorry the boards are still 2009 a1181 versions !
完成的
Okay so they're not the Unibody style? It matches this: MacBook Core 2 Duo
完成的
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 127
