screen shows everything double. What can I do?
i left my phone for a few minutes on the sofa and then when i come back the screen shows everything doubled.
Steps
1. power off button on the phone, press it
2. check the pop up on the screen (power off, restart, airplane mode, silent mode, VR mode)
3. Tap on the VR mode.
Bingo! problem solved.
这个答案有帮助吗?
very good answer and simple but very useful
This answer saved me.. thanks a lot
I dont have vr mode ,what to do,?
When you press switch off button... one extra message is displayed i.e. "VR Mode is ON".... just select that option... you will get back the original screen
这个答案有帮助吗?
Where is vr mode located
I freaked out when it happened but I turned it off. Then took the battery out and light pressed on the back where the battery sits. Put the battery back then turned it on then, it was fixed
这个答案有帮助吗?
You can't fix it with the apps or in the settings. You gotta repair it or simply just buy a new one🥲
这个答案有帮助吗?
过去 24 小时: 5
过去 7 天: 36
过去 30 天: 184
总计 23,002
8条评论
I have the same problem for a LG Stylo 3 that was stepped on.
由 April Smith 完成的
did u fix it i got the same problem and same phone
由 Jing Jing 完成的
由 Swetha Thomas 完成的
no my phone fell on the groud
由 zyasiamorgan5 完成的
Does this drain my battery?
由 Nancy Yengel 完成的
显示更多的3条评论
