跳转到主内容
联想手机维修指南。
284 个问题 查看全部
screen shows everything double. What can I do?
i left my phone for a few minutes on the sofa and then when i come back the screen shows everything doubled.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
8条评论
I have the same problem for a LG Stylo 3 that was stepped on.
完成的
did u fix it i got the same problem and same phone
完成的
完成的
no my phone fell on the groud
完成的
Does this drain my battery?
完成的
显示更多的3条评论
添加一条评论
5个答案
最有帮助的答案
Steps
1. power off button on the phone, press it
2. check the pop up on the screen (power off, restart, airplane mode, silent mode, VR mode)
3. Tap on the VR mode.
Bingo! problem solved.
这个答案有帮助吗?
得分 5
3条评论:
very good answer and simple but very useful
完成的
This answer saved me.. thanks a lot
完成的
I dont have vr mode ,what to do,?
完成的
添加一条评论
When you press switch off button... one extra message is displayed i.e. "VR Mode is ON".... just select that option... you will get back the original screen
这个答案有帮助吗?
得分 2
1条评论:
Where is vr mode located
完成的
添加一条评论
I freaked out when it happened but I turned it off. Then took the battery out and light pressed on the back where the battery sits. Put the battery back then turned it on then, it was fixed
这个答案有帮助吗?
得分 0
添加一条评论
You can't fix it with the apps or in the settings. You gotta repair it or simply just buy a new one🥲
这个答案有帮助吗?
得分 0
添加一条评论
My phone shows ng double screen
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dragneel Potter 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 37
过去 30 天: 185
总计 23,003
