跳转到主内容
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
Screen bent back, how to remove and fix?
So yea, my MBP was on the coffee table and my 2 year old they a sofa pillow and bent the screen back. Now, the screen will not close down. Well, I can get it to, but its like trying to stuff an overpacked suitcase...effort is needed. Also, once I pop the latch, the screen shoots open due to the tension.
Is there anyway to SAFELY remove the screen and surrounding frame so that I can bent it back into shape? I guess Ill try asking iFixit
Pics:
http://qkpic.com/b98d1
http://qkpic.com/5b167
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
4条评论
we need to know exactly which 17" MBP you have.
完成的
17in MBP 2.14 June 2006
完成的
If I follow the guide to replacing the hinges, will that be a good guide for achieving my solution?
完成的
2006 had a 2.16 but not a 2.14
完成的
添加一条评论
1个答案
最有帮助的答案
I would take it apart and see if I could detect the part that needs replacing or repairing. Follow this guide: MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Display Replacement
这个答案有帮助吗?
得分 2
2条评论:
完成的
完成的
添加一条评论
添加你的答案
Kaliber35 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 913
