跳转到主内容
The RIDGID R86034 is a Lithium Ion impact driver manufactured by RIDGID in 2012.
10 个问题 查看全部
Dropped it in water
Dropped the impact driver in water now the battery and driver won't work.. Can it be fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Unless you can clean the PCBs and replace the battery, I doubt it’ll survive especially if the motor is bad. I would get the battery replaced if possible, and then try to repair the bare tool. If the tool is beyond repair, then you will probably be better off replacing it with a “tool only” replacement, and letting them know the old one is dead due to liquid if you need to do that.
More then likely, the tool will be a total loss unless you can fix it, or get a pass for accidental damage. If the battery isn't covered you usually get a better deal on 2 packs. I would check that first before risking getting caught.
这个答案有帮助吗?
得分 2
添加一条评论
will be ok in a few days just let let dry out first, use a different battery... not the one that went in the water
这个答案有帮助吗?
得分 0
1条评论:
Downvoted for mentioning rice.
完成的
添加一条评论
No, put in for warranty and the just send you a new battery. They have lifetime warranty if you registered it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Welbanks 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 40
总计 1,543
