跳转到主内容
加入维修社区 - 创建账户
Repair information for PowerBook G4 Aluminum laptops with 15-inch displays.
Laptop won't charge battery
The 1.67 GHz laptop won't charge the battery. The computer will turn on when plugged in but the indicator will show "Battery not charging" I have tried another batttery and charger so I've ruled that out. The only thing I can think of is that the power cable from the board to the battery went bad or got bumped out of place. Any one have any ideas?
Thanks.
JB
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi! There's a chance that the cable you mentioned is faulty, but if you're 100% sure the battery you are testing is good, it's likely the DC-in module in the computer that is bad. This piece of hardware controls power-related functions. Here's one for the A1138 PowerBook 15" 1.67GHZ machine (you'll want to verify your model number and look it up in the iFixit parts store to make sure to get the right part):
http://www.ifixit.com/PowerBook-Parts/G4...
It's not an easy repair, but it's do-able, and there is an iFixit guide to walk you through the process.
这个答案有帮助吗?
得分 1
添加一条评论
Sounds like you need to replace the battery- they get old. How old is it?
这个答案有帮助吗?
得分 0
1条评论:
I have changed the battery
完成的
添加一条评论
添加你的答案
jeanb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 1,137
