跳转到主内容
这是一系列帮助修理洗衣机的指南和支持。
Machine not working , Error dE
Although the lid is closed and the magnet attached to the lid is intact, the door open error message (dE) is displayed and the machine (LG fuzzy logic model no. T6515TDPT01) stops working after taking two /three turns in wash mode. I seek help from you guys to fix the problem. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Check to make sure that the connector coming from the switch is properly seated on the circuit board.
完成的
添加一条评论
2个答案
最有帮助的答案
Might be the magnet, usually the magnet pushes this switch the shows the door is closed. Hard to explain. Do you happen to have pictures?
这个答案有帮助吗?
得分 1
1条评论:
I shall fix a stronger magnet and shall see if it works.
完成的
添加一条评论
Power off the machine and unplug it if you receive the error mid-cycle or at the end of the cycle. After five minutes, restart the machine and try to open the door again.
Wait about a minute for the door to unlock if you paused the machine during a cycle. In this situation, the locked door and appearance of the DE error is merely a safety precaution.
这个答案有帮助吗?
得分 1
3条评论:
Simple and great solution!
完成的
I could not get you dear gillrois. plz explain elaborately.
完成的
Click on the link for troubleshooting LG washer with error code DE. Hope this help Immi.
http://www.ehow.com/how_7850983_troubles...
完成的
添加一条评论
添加你的答案
Immi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 364
