跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
问题已关闭
Home Button Flex Cable Replacement wont work, but old cable does?
I am repairing an iPhone 6 Plus, and received an Error 53. I decided to change out the home button flex cable to make sure the home button was original and now the home button does not work at all. The new cable allowed me to update the phone, but the home button will not respond at all.
I am unsure of what to do. I have plugged the old cable back in and get a response, but no matter how many times I readjust the new cable, it will not respond.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The home buttons on all iPhones since the 5s and newer are paired to the phones motherboard. If your old button doesn't work your best bet is to enable assistive touch. Your phone will never be able to update without the original button even if the replacement worked. I would strongly recommend getting a out of warranty replacement from Apple. It will save you trouble in the long run.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 98
