跳转到主内容
device part number is not matching
A 1278 core 2duo
I have changed my magsafe board which was giving charging problem.
After few days same problem reoccured
I saw the part number on ur site as
880-2361-02
whereas magsafe board on my laptop says
880-2361-A.
I dont know if both are same or this difference in part number has caused the reoccurence of the problem.
Is there any waranty on this board offeref by APPLE as the repair was done ona apple authorised repair centre
Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
The actual Apple part number is 661-5235. This MagSafe part is interchangeable in all Unibody 13". Slight variations in part numbers is very common as Apple uses several manufacturers.
这个答案有帮助吗?
得分 1
4条评论:
but one used on mine is of 17" 2.8GHz MACBOOK PRO
not of 13" MACBOOK.Can you tell me wat damage it could hav done? After changing magsafe board my macbook worked for few days but sometimes screen use to turn dark.Now again battery is not getting charged
完成的
Frankly I can't find either one of those part number listed anywhere on the web with the exception of this question. Where did you get them?
完成的
661-4950 is the number I get for the magsafe board for the unibody 15/17. +
完成的
完成的
添加一条评论
添加你的答案
Puneet Singh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 762
