跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
Weird Screen Issues?
I have an original iPod video that has some weird screen issues. Sometimes, the screen shows many lines (both horizontal and vertical) that are always on top of a blank white screen. Other times, the screen is fine. Currently, the harddrive is dead, but I am planning on ordering a flash to ZIF converter thingy off eBay.
So, my main question is, am I looking at an LCD problem or a motherboard issue?
EDIT: Okay, so I turned it on (still with the dead harddrive), and I got the Apple logo, then the sad iPod logo. It kept rebooting (as the harddrive is toast), but on about the 5th reboot, the screen went white and had the aforementioned lines appear. So now I ask, could the harddrive play any part?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
try checking all of the ground straps, they ground everything to the internal framework, which is grounded to the logic board for one common ground, most likely one of these isn't making contact always, so the operation may be intermittent, or, your display connector might be lose if the problem is caused by shaking the iPod
这个答案有帮助吗?
得分 0
4条评论:
What exactly would a grounding strap look like on the iPod?
完成的
it's a silver metallic tab with adhesive on the back, there are a few in this ipod, one on the top of the logic board above the buttons, one on the clickwheel, it's attatched to the cable, and branches off, there might be one on the screen, but i don't remember 100% correctly if there is one or not, also there might also be one on the battery, but that connects to the backplate if it exists on yours.
完成的
Would it be this little tiny bar of shininess under the LCD?
完成的
Yep, that's one of them, that connects the logic board to the common ground.
完成的
添加一条评论
It could be he logic broad were the LCD connects to it. If you are trying to fix it i would buy a new logic broad and a new hardware. I've just start to fix I pods and I have a 5th gen just like and they seem to be the easiest to fix. if you have any more question ill check tomorrow.
这个答案有帮助吗?
得分 0
添加一条评论
Any update to this thread? I have the same screen problem issue with mine.
这个答案有帮助吗?
得分 0
1条评论:
Check the time line on this. 4 years without any response, mighty unlikely that you will get an update. I suggest you ask your own question and give as much detail as possible. I bet you get a quicker response to your own question than waiting for an update. Use this link to ask http://www.ifixit.com/Answers/Ask/iPod+5...
完成的
添加一条评论
添加你的答案
Josh Calvetti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 25
总计 4,454
